smog ? : failed smog (CO and HC reading are too high) what is HC?
Old 02-07-2006, 02:36 PM
EE:OutofBounds's Avatar
Default smog ? : failed smog (CO and HC reading are too high) what is HC?
seems like I'm running rich (im at +8% primary fuel) Just by leaning it out (primary fuel set to 0 and leaning out increasing load) "SHOULD" do the trick no? I'm running cats btw. TIA
Old 02-07-2006, 02:39 PM
Andrew C.'s Avatar
hydrocarbons
Old 02-07-2006, 02:40 PM
im_cecil's Avatar
Default Just went through the same thing. HC is hydrocarbons -- basically, unburned fuel.
Lean it out, retard the timing, new plugs. If you're in CA, though, they're supposed to do a manual timing check, so it needs to be set to spec.
Old 02-07-2006, 02:56 PM
EdyJun's Avatar
Default Re: smog ? : failed smog (CO and HC reading are too high) what is HC?
Is there anyway for you to do some detail logs? (ECUx preferred) I am very interested to see what the timing, MAF,CF, and O2 readings are.
Edy
Old 02-07-2006, 02:58 PM
Default ill send you some when I get back tonight
seems like i've been running rich for awhile now =(
Old 02-07-2006, 02:59 PM
cool thanks.....i'l lean this b*tch out and hopefully itll be fine
Old 02-07-2006, 03:43 PM
OldSkewS4's Avatar
Default BTDT
Lemmiwink primary to -2% it should pass no problemo.
Old 02-07-2006, 03:48 PM
EdyJun's Avatar
thank you
Old 02-07-2006, 03:49 PM
gracias David =)
Old 02-07-2006, 04:10 PM
Member
Ochlockonee's Avatar
Default Make sure your cats are nice and hot before the test too. They chew up HC/CO at operating temps.
If you are missing @ idle your HC/CO #s are pretty much unstoppable.
Quick Reply: smog ? : failed smog (CO and HC reading are too high) what is HC?
