so had bad is this 10% ethanol mix in gas for our cars?
#22
<center><img src="http://journeytoforever.org/biofuel_library/ethanol_manual/z-image/fig2-5.jpg"></center><p>
AFAIK we're getting 90 octane gas with 10% Ethanol added to bring the total octane to 93.
The problem is, Stoich for Ethanol is much richer than Gasoline (I hear 8:1) so your overall mixture must be substantially richer than 100% Gasoline. Also, Gasoline has 124% the energy of Ethanol.
On paper, It looks "OK" but in practice it's a giant ball of suck at higher cylinder pressures. As the chart above illustrates, these are two vastly different fuels, with Ethanol having a very narrow effective AFR range.
This problem has affected multiple vehicles, even NA ones. One interesting item of note: LS1's running hypertech programming are now experiencing audible pinging and now must run in stock-mode. Hypertech squarely blames the fuel and has no solution as of now
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
#23
Basically.. it's a huge scam IMO. The government subsidizes it, and the only benefit is to the corn growers association, who interestingly enough lobbies behind all the ethanol blends of anything.
#27
My car is running crazy cylinder-pressures so I've had to add 10% fuel. I figured a more conventional stg3 would need half that since it doesn't seem to be a linear relationship.
Anyhow, good info.
Anyhow, good info.
GDawgA4
01-14-2008 11:33 AM
djnelsen
04-26-2002 09:48 AM
