So i am thinking about going home brew...
I have so far a Giac x chip (tweaker file) and k04/k16 to install i would like to go homebrew what are my options as far as ionjectors and maf? I want to keep my existing software...Would that be a problem? Can i get a buhen MAf and some green top injectors tcd mbc and call it a day or what anyhelp would be great TIA.
Can someone explain this tweaker file to me? Apparently I'm out of the loop with regular v.8 chip.
I remember Moss mentioning it, but didn't get around to asking for details.
To answer your question, there are tons of MAF/injector combos you can use because it doesn't need to be a perfect match...just close enough where Lemmi can make up the difference. For example, I run a RS4 MAF housing converted to use stock Hitachi sensor, 38# delphi injectors @ 4bar (460cc/min), and -20.5% primary fuel in Lemmiwinks.
No dyno or timeslip from dragstrip, but many FATS pulls with data posted here on it.
I'd say it's pretty quick, just maybe a touch faster than regular stage 3s. Usually FATS times are in the 3.5-3.7 second range if that means anything to you.
I hope to dyno it soon and maybe take it to the strip although nobody ever wants to go with me.
Also i have an 01 so i have a hitachi maf already would it be easier for me just to buy a ASP...
or Buhen maf housing and use my stock sensor? Also would greenies flow well enough to support my k16 option?
