So I put a new timing belt on tonight with the cam lock bar in place. Torqued the cam gears on with
<center><img src="http://pictureposter.audiworld.com/27288/img_1996.jpg"></center><p>the 15nm of tension being applied to the tensioner per bently. After it was all done I removed the bar and it kind of popped because there was too much tension along the top run of the belt. It now wont go back on easily and I don't want to force it.
Can anyone tell me what went wrong?
Torque the pulleys back down with the cam lock bar in place after you tension the belt.<ul><li><a href="http://tychl.txf.com/artiming/MVI_0328.AVI">video of pulley spinning</a></li></ul>
belt.
Soo, lets check order of operations
pulleys free spinning
cam bar in place.
tensioner pin pulled
apply 15NM torque to the tensioner pulley to tension belt
remove 15NM torque
torque cam pulley bolts
remove cam bar
cam bar in place.
remove 15NM torque
remove cam bar
pulleys free spinning Yes
cam bar in place. Yes
tensioner pin pulled NO
apply 15NM torque to the tensioner pulley to tension belt Yes
remove 15NM torque No
torque cam pulley bolts Yes
remove cam bar Yes
I didn't pull the pin on the tensioner. I had a friend hold 15nm of tension with a torque wrench and pulled the pin after.
Bently dosen't actuall say to pull the pin ever.
remove cam bar Yes
"Using a hex key, turn toothed belt tensioning roller -1- clockwise 8 mm in direction of arrow until special tool T 400 11 can be removed."
T 400 11 = pin thingy
Then it says to tension belt to 15nm and then tension cam pulleys.
Try this:
pop the cam pulleys again
put cam bar back on
slowly detension the tensioner pulley until the belt is slack
allow the tensioner to extend on its own
use your torque wrench to apply the 15NM of torque to the tensioner
take off torque wrench
then tighten the cam pulleys again
Try this:
put cam bar back on
I did a timing belt just this last weekend, even after turning the engine over enough to bring the timing belt around 1 revolution of the belt I was still able to wiggle the cam bar back in place.
Good luck!
Good luck!
