Sodium cooled valves?
Guest
Posts: n/a
Sodium-cooled valve: An exhaust valve with a hollow stem that is partially filled with metallic sodium. When the valve gets hot enough (138°C), the sodium melts and moves up and down in the valve stem. The sodium absorbs heat from the hot valve head and carries it away to the outer part of the stem and then into the valve guide in the cylinder head and next to the cylinder head itself. This circulation cools the valve head and thus the valve is allowed to run at a lower temperature.
Guest
Posts: n/a
For one of my senior level classes back in undergrad, I worked with internal combustion engine designing (piston design and pre-chamber combustion) and that sodium cooled valves sounds really neat. Where did you get this info and do you know of any other cars that have these?
Drew
Drew
Guest
Posts: n/a
It is not that new for sport engines.
The exhaust valves are filled in with a sodium component inside , which acts like a cooler for the valves.
I remember the first Alfa Romeo of my father was already equipped with this feature (in 1976).
All Ferrari or BMW Alpina have that feature since ages.
Notwithstanding, the S4 has an extremely well shaped engine. But it is mainly due to electronic components.
UrS4boy
Audi Original "S" Cars
08-28-2008 08:07 PM
4x4a4(nomore)
04-15-2003 05:35 AM
alfa, audi, cooled, exhaust, explanation, filled, invented, piston, romeo, s4, sodium, sodiumcooled, sodiumfilled, valve, valves
