Some Stage 3 MAF math - (say that three times fast (discussion))
Old 12-08-2005, 07:08 PM
Member
E Vader's Avatar
Default Some Stage 3 MAF math - (say that three times fast (discussion))
(Obviously there are generalizations made in the below math and they should not be considered absolutes)
RS4 K04 turbo characteristics:
K04s at 1.6 bar (23.52psi(70% efficientcy)) flow approximately 0.15 m3/s (or approximately 318 cfm)
There are two turbos in the S4 so the total potential CFM should be 0.30 m3/s (or approximately 636 cfm)
MAF characteristics:
Stock S4 MAF 73mm
Common conversion 88mm
MAF reading offset 1.45 correction factor.
Topic for discussion:
If 1 g/s = 1.77 cfm (approximate average given temp modulation) then an 88mm MAF reading 250 g/s = 362.5 g/s (when correction factor is applied) would approximately equal 640 cfm.
(I realize that there are temperature range air density factors in the MAF conversion but, I chose to simplify the discussion by leaving that out since a 40-100 deg range assumes similar basic air density of modest significance)
Question for discussion:
How can a 1.6 bar, 636 cfm potential max boost system provide a MAF reading of greater than the total potential cfm?
Is my math wrong here?
No particular car is implicated in this example as this is a math topic for discussion.
Old 12-08-2005, 07:12 PM
Rest In Peace
Jeff Vader - boscoj's Avatar
math maf, maf math, math maf . . .
Old 12-08-2005, 07:13 PM
rktskicar's Avatar
How much higher than 636 cfm is it?
Old 12-08-2005, 07:20 PM
Member
E Vader's Avatar
Default I want to stay focused on the....
..."how can it be higher" rather than the "how much".
Because the topic could digress. I think my math may not correctly account for g/s (air flow) vs cfm (volumetric measurment) in the presented example.
Side note: The case of the vehicle in question is considerably higher.
Old 12-08-2005, 07:27 PM
Member
Ochlockonee's Avatar
Bad maf, or screwy velocity in maf housing are possibilities.
Old 12-08-2005, 07:30 PM
Member
E Vader's Avatar
Default Agreed.
By common "dart at a dart board" methodology a car with 362 g/s x 1.29 should be a 466hp car.
Old 12-08-2005, 07:49 PM
Ah10@WMS's Avatar
Default How do you figure out maf correction factor?
shouldnt it be:
73mm vs 88mm maf should be 1.2055
73mm X 1.2055 = 88 so if 88mm maf reading is 250g/s wouldnt it mean 301.375? then the CFM would be much lower!
Old 12-08-2005, 07:55 PM
Jason @ Streetwerke's Avatar
Default Where are you getting your MAF reading offset correction factor from?
Delta in cross sectional area between the two?
Old 12-08-2005, 08:01 PM
Mike2kS4's Avatar
Default Most likely the airbox outlet/air intake is turbulent.
You could also have a boost leak on the pressurized side... metering more air then is actually being used, so you may be flowing 1.7bar worth of air to get your 1.6.
Old 12-08-2005, 08:02 PM
Mike2kS4's Avatar
Area of a circle. Calculate it again It's pretty accurate at the airflow speeds we're seeing.
Quick Reply: Some Stage 3 MAF math - (say that three times fast (discussion))
