Spark plug non-fouler update...
Many of you know I've been trying to use spark plug non-foulers on my piggie's instead of relocating the 02 bungs.
The mod calls for 2 non-foulers stacked on top of each other with the top fouler drilled out and the bottom fouler left alone. B/c of a miscommunication w/ my installer, I've been driving around w/ the bottom fouler drilled out only and alas, I was getting cat efficiency codes, failing my readiness readings, seeing a semi-frequent cel and getting hesitation I could not put my finger on.
Well, I'm happy to say that I got the other foulers put on last night, reset my codes and have yet to see a cel, cat efficiency codes, my car doesn't have the slight hesitation anymore and I PASSED all my readiness blocks so emissions shouldn't be a problem now.
Please note that I've only tested these for about 30 miles so I can't say for certain that they definitely work but I will give you updates after more testing is completed.
<b>The pics are not from an S4 but you get the point.</b>
<img src="http://baper.net/~enjanir/mech_o2_sim/1.jpg">
<img src="http://baper.net/~enjanir/mech_o2_sim/2.jpg">
<img src="http://baper.net/~enjanir/mech_o2_sim/3.jpg">
<img src="http://baper.net/~enjanir/mech_o2_sim/4.jpg">
Drill out 1 of the foulers with a 1/2" drill bit. This one will go on top.
<img src="http://baper.net/~enjanir/mech_o2_sim/5.jpg">
<img src="http://baper.net/~enjanir/mech_o2_sim/6.jpg">
<img src="http://baper.net/~enjanir/mech_o2_sim/7.jpg">
<img src="http://baper.net/~enjanir/mech_o2_sim/8.jpg">
<img src="http://baper.net/~enjanir/mech_o2_sim/9.jpg">
<img src="http://baper.net/~enjanir/mech_o2_sim/10.jpg">
<img src="http://baper.net/~enjanir/mech_o2_sim/11.jpg">
The 02 sensor is out of the exhaust stream so it won't trigger the cat efficiency codes. This should also work for those running test pipes.
<img src="http://baper.net/~enjanir/mech_o2_sim/12.jpg">
For the past week I was getting them occasionally while logging or extended drives but that was when I was only using 1 instead of the recommended 2 stacked.
I was also getting cat efficiency codes and failing Readiness constantly. I would trigger these codes as soon as my car warmed up to operating temperatures.
Gutting the precats is a very labor intensive process and very hazordous to your health. You do not want to take a chance breathing in that dust cause you can seriously fvck yourself up permanently.
The only reason I didn't was b/c my stock dp's were fubar'd from hitting road debris so I didn't have a core to supply and my installer didn't have a welding machine so I had to think of other options for relocating the 02's. Just play it safe and get them from Vast.
<a href="http://www.vastperformance.com">Vast Performance</a>
