Speed Sensor Wire to Instrument Cluster?
Does anyone know what color the speed sensor wire is going to the cluster from the ECU and on which plug it can be found. I have tried cutting the white/blue wire on the brown plug at the ECU, the brown/red wire on the green plug at the cluster, as well as cut two white/blue wires going to the blue plug on the back of the cluster and I still have a speed signal. I need to know which wire it is so I can install a speed ratio adapter. I searched the forums and found that it was supposed to be a "white/blue" or a "brown/red" wire, but apparently not. If someone could let me know which wire to tap or post wiring diagrams of the ECU or instrument cluster it would be much appreciated.
But I don't know if this is actually correct since none of the other information I found through searches seemed to work.
But I've got to get the one going from the ECU to the speedometer in order to not affect the ESP/ABS system. What I need it for is to place a ratio adapter inline to change to speedometer reading.
Cruzad3r
14
03-30-2007 11:23 AM
Audi S4-GASM
05-02-2005 08:19 PM
BLK01S4
04-22-2005 04:49 AM
scott12v@pghaudi
10-31-2001 10:21 AM
