SQUEEEEEEK when dry steering
Ok - 2000 S4, 110k. Bilstien Sport Shocks and H&R coils all front control arms replaced.
I don't think this is indicative of a major problem, but I wanted to see if there was a quick and cheap fix for this or if others have the same issue.
On "dry steering" when the car is stopped or moving slowly the car emits a metallic screeching noise. This occurs mostly when the steering angle is more extreme, as when reversing out of a parking spot, ect. I figure something in the steering system needs a little grease but before I waste time lubing top to bottom maybe someone could point me to the culprit. My guess is the rack - do you concur?
Squeek or squeel? I wouldn't do anything to the rack, the system is lubricated by the steering fluid itself. I would check the steering rack/tierod end boots to see if they suffered damage, and/or are filling up with p/s fluid.
EDIT: Forgot to say, if sounds kinda like finger nails on a chalk board + licked finger making a crystal glass hum. This is normal. I think this is sound is from the high pressure build up at extreme steering angles.
:END EDIT
Side story:
I had a high pressure seal fail due to a slap dick doing a ****ty job installing tierod ends. Didn't replace the boots properly. p/s fluid leaked like crazy out of the tie rod boot. Then once I got the rack replaced I got a temp alignment from a shop so I wouldn't finish killing my tires tires before I could get them replaced.
This place didn't adjust the boot and left it all twisted and nearly tore the new boots which would have lead to the same failure I had just repaired.
symptom of this failure was very wierd sound, hard to discribe sounded like it was comming from the u joint into the car...
:END EDIT
Side story:
Comp and Rolled
Thanks to the both of you! PS fluid needs to go for sure. Tie rod ends are still good (for the moment) but I will check the other parts you mentioned.
By the way, excellent description of the audible symptoms! That is exactly the sound I'm getting.
Cheers!
Cheers!
nooffswitch
09-10-2008 07:40 AM
kodeTT
17
05-22-2007 01:51 PM
Chris not @ Toyo now
15
07-01-2003 09:43 PM
