is stage 3- a big jump from stage 2+? i just cant get a grasp on how much of a power gain it is
Depending on what turbos you get, of course. If you got straight K04s, you're going to lose a little bit of bottom-end grunt for some more top-end.
It does depend on what turbos, though.
As for actual numbers, some Stage 2+ and Stage 3- searches for FATS/dyno charts would help get a rough idea of that.
Try checking timeslips on <a href="http://www.s4biturbo.com">http://www.s4biturbo.com</a>
<ul><li><a href="http://pictureposter.audiworld.com/44443/112305_bej_s4_k0411x_compare_adj.jpg">GIAC 2+ and 3- HP compare</a></li></ul>
to get my injectors cleaned and full 3 is MUCH faster than 3-. IMO, the guys who are planning on staying 3- are wasting a good set of K04's.
..just me tho.
..just me tho.
First off, they really give you more pull in the high rpm range. K03's are past efficiency well before redline. When I put the ko4's in on APR software, I noticed a definate increase in performance especially up top. The car just overall ran smoother. With the GIAC software, it pulls pretty good.
I went from APR Stage 2+ to APR Stage 3- to Revo Stage 3- to GIAC Stage 3 -. Seeing you already have Garret software, I think you'll be happy.
I didn't notice an increase in turbo lag. Now with the MBC in it makes boost quite quickly. Also, keep in mind running 19-20psi spike on ko4's isn't out of their efficiency range. With a manual boost controlller and anti-throttle cut circuit you can definately make a decent jump in perfromance.
