Stage 3-, possible alternative to MBC (longish)
Old 03-18-2004, 06:39 PM
New Member
K-daddy's Avatar
Default Stage 3-, possible alternative to MBC (longish)
I wonder if anyone has thought of this idea for running stage 3- without an MBC.
The reason for the MBC is that the bigger turbos spool late and very rapidly and the ECU feedback loop is not fast enough to keep the boost in check. The result is that it spikes quite high then recovers.
I see that VW guys get "Race N75" valves that give you more boost by opening up the bleed port on the boost solenoid. This causes the same effect where the ECU cannot keep the boost in check and it overshoots. (Terrible idea, IMHO)
So, what about using the stock electronic boost control, but restricting the bleed line of the N75, perhaps with a needle valve? That means that the stock feedback loop should effectively be faster because there is less bleed off so the actuator will move sooner.
This system would allow you to retain the stock boost control (very elegant IMO) without the boost spiking problems. Now, if the requested boost is reduced at higher RPM's (in anticipation of K03's being flowed out) you would still have that reduced boost vs. an MBC. But, you are probably risking outflowing the injectors or hitting fuel cut at that point anyway.
Just a thought. Wanted to know what people think. I think I am going to be in the position of needing a stage 3- solution myself in the relatively near future.
Thanks,
Karl
Old 03-18-2004, 06:43 PM
VerrÜckt's Avatar
Default Would be worth a try, but ultimately an MBC in parallel with the N75 would suffice too.
But with the tapering to redline, you won't be maximizing the upper RPM flow of the K04's.
Old 03-18-2004, 06:46 PM
Junior Member
Bramell-EVOvert's Avatar
Default I like people like you...
Couple of things:
1. I would be worried about wastegate flutter, since it would take alot less pressure to open the waste gates.
2. If your run the MBC in parallel, like i did on my old car, it cuts off the spike, and then lets the N75 take over. This actualy worked out really well. I pulled 2-4 cars on stage 2+ cars.
Old 03-18-2004, 06:47 PM
Junior Member
Stock fueling is only good for about 15 psi on k04s. I believe troy did the caculations on this.
Old 03-18-2004, 06:50 PM
Funkweasel's Avatar
Darin and Mike were central in that discussion as well. Thanks for the shout out too.
Old 03-18-2004, 06:52 PM
VerrÜckt's Avatar
^^ ^^ Important point.
Old 03-18-2004, 07:39 PM
Imolavirus@BuehnEngineering's Avatar
stock fueling = stock FPR and injectors or just stock injectors
Old 03-18-2004, 07:43 PM
Ray Khan's Avatar
how bout an EBC?
Old 03-18-2004, 07:47 PM
Default just an ebc or one in parallel with N75? if its with the N75, it would just be like the MBC only
not have to adjust it in the engine bay
Old 03-18-2004, 08:40 PM
Junior Member
Umm i think with a 5 bar...maybe darin can chime in tonight?
Quick Reply: Stage 3-, possible alternative to MBC (longish)
