starting and shutting down engine
Old 03-24-2002, 02:45 PM
MR711's Avatar
Default starting and shutting down engine
Is it true that with turbo-charged engines you are supposed to let the engine idle for a minute or so when you start up and when you shut down.
Old 03-24-2002, 02:50 PM
gk1
gk1's Avatar
Good idea for any car.
Old 03-24-2002, 02:51 PM
Mr.FRU-T-Pants's Avatar
Default It's important to warm up the engine oil before hitting the throttle too hard.
It's also wise to let the turbos spin down, and cool off, before shutting the engine down, yes.
It can be done two different ways that are practical, either w/ a turbo timer, or by granny driving for the last few minutes of driving. This only pertains to a car that's been driven relatively hard, though, when engine temps are higher than casual around town driving.
Old 03-24-2002, 03:03 PM
RedBlackYellow's Avatar
Default i think he's referring to if he's just gonna start up the car and like move it an inch and then
shut it off, should he idle it, and the answer is yes.
Old 03-24-2002, 03:04 PM
Member
Audi Dudey's Avatar
Anyone have any experience of check engine light coming on after car wash in very cold weather?
Old 03-24-2002, 03:39 PM
Singletrack's Avatar
Default Why would you need to idle it after moving it only a small distance?
The engine and turbos haven't even heated up yet.
-st
Junior Member
Brit NOT in Exile's Avatar
Default ASK ERIC FLETCHER he knows EVERYTHING!
i think it is a VERY good idea to let your engine idle for a minute before shutting it off. I believe it helps stabilize temps and let the turbo slow down especially if you were running it hard. Others here TOTALLY disagree with me so there you are. But then I have a superior TIPTRONIC too, and all the EXPERTS agree that a stick shift is better right up until the time that they destroy their gearbox by adding a short shifter and not knowing how to drive a stick in the first place. (A good driver in a tip will take the average driver in an S4 with a stick almost every time.)
I think I must be going crazy....well my tour over here is almost up so I think it doesn't matter much.
Cheers
Old 03-24-2002, 03:44 PM
Default No you do not have to let the car idle before driving it but...
you should take it easy until the oil has time to heat up. There once again seems to be some debate as to whether or not you need to let the car cool down after driving it hard. I always let it sit 1-2 mins at idle and I also take it easy for the last few minutes of the drive. Some people don't think this is necessary because of the water cooled turbos in the 2.7T engine.
Actually letting the car sit and idle after starting it will cause more engine wear, at least according to the manual. I assume since the oil will take longer to reach its optimum operating temp. Start the car and drive it, don't let it idle.
-st
Old 03-24-2002, 03:46 PM
Here we go again...
Old 03-24-2002, 04:10 PM
Junior Member
0!1qu!ckAvant!'s Avatar
So that means no pics of your car at the base ? No suprise.
Quick Reply: starting and shutting down engine
