Stasus Street Sport Suspension - What height is everyone running? Any effect on performance?
#11
---> to 25.25" will improve your handling (though not much) because:
* It lowers your car's center of gravity, thereby lessening the tendency to roll in turns.
* It sets more negative camber, thereby increasing outside tire grip in cornering near the limit.
* You may notice slightly more responsive turn-in.
On the negative side, it will increase inside tread wear in regular driving.
These effects increase with further lowering.
#19
Former Vendor
It's not easy, and there are some tricks to it. It helps if you get theplastic shims between the spring and lower perch. But it's certainly doable.
#20
I've done it a couple times now. I've noticed that the new kits come with a spacer between the front dpring and collar to allow for free movement of the collar when adjusting height.
