Status Update -4 - Imola Beast - Spread Legs
#27
If you use the washer fluid tank as your reservoir, then the only added weight is from the pump, the lines and the heat exchanger (relatively minimal).
The gains in charge air cooling (and subsequently, timing if you have programming to take advantage of it), could far outweigh the added weight.
-Dave Pramanik
-Dave Pramanik
