StgIII Awe fueling kit VS Asp Fueling kit.. please chime in with reasons!
#22
I'm 100% behind it.
Just to make people aware, you know? If somebody thinks they can get 459 on pump, whoo boy they are going to be pissed when they get 350.
#23
I'm not kidding.
Get some stiffer springs in there too...holy wheel gap Batman! =)
#27
The price of the K04 Fueling Package is $2199
Our K04 Fueling Package consists of the following items:
<img src="http://pictureposter.audiworld.com/93546/k04-fuel.jpg">
[1] CNC 85mm MAF Housing for Stock Air Box, Uses Hitachi Sensor Only
[1] RS4 MAF Hose
[2] MAF Hose Clamps
[6] Delphi 440cc/min, (42lb/min) Flow Matched Injectors
[4] Phenolic Fuel Rail Spacers
[4] Fuel Rail Stainless Hardware
[6] Bosch Platin F5DP0R Spark Plugs
[1] Upgraded MAP Sensor
[1] MAP Sensor CNC Adapter Plate
[2] MAP Sensor Stainless Hardware
[1] MAP Sensor Wiring Plug
[3] Heat Shrink Sleeves
[1] ASP K04 Performance Software
Some specifics regarding our software:
<i>-The boost requests are re-mapped to deliver a quick 24psi peak to 21psi taper by redline. The 24psi is not sustained and occurs only at maximum requested load to get your vehicle moving.
-Increased Ignition Timing for Better Performance
-Redline is set to 7,100rpm vs. Stock 6,800rpm
-Speed Limiter is Removed
-Fuel Consumption Gauge is Recalibrated to the New Injector Flowrates
-Check Engine Light (CEL) is disabled to Allow use of our ASP Race Pipes
-ReScaling of MAP Sensor to Accurately Display Pressure Values > 22psi
-Allows use of 91 Octane</i>
<b>Performance is very strong with our Package, see Dyno Chart</b>
<img src="http://pictureposter.audiworld.com/93546/dyno1.jpg">
It is important to note that a stock S4 produces approximately 175whp on this Dyno Dynamics dyno, owned by <a href="http://www.gocpt.com"> Chicago Performance & Tuning</a> (They are an Authorized ASP Center) which are known to output "low" numbers. Our kit generates approx. 347whp and 400ft-lbs of wTQ. The closest competitor's kit highest numbers ever dyno'd there was approx. 320whp.
Lastly if at any time you need support and would like revisions to your software, we can perform the Motronic programming in-house, onsite. We do not rely on other tuners to make these programming changes for us.
Hope this helps, I encourage you to contact us by phone if you need and additional information.
[1] RS4 MAF Hose
[2] MAF Hose Clamps
