Still have questions prior to Subwoofer install...
The bazooka tube that I have suggests using high level inputs, and to tap into the rear speakers. Where is the bose amp? I would like to tap in prior to the amp.
signal from the wires going to the speakers and no more noise. Of course, your amp has to accept speaker level inputs.
amp is behind carpet right forward of the cd changer cubby. You must unscrew the rear trim of the trunk where the latch goes. then loosen the nut right behind the taillight and then yank the carpet on the siide of the trunk out. It is clipped in. use the pinnout from the tech section to use the rear deck outputs for your sub
1.8TForMe
02-17-2005 01:21 PM
Chicktronic
12-23-2004 01:27 PM
Jestapilot
10
05-01-2004 05:47 PM
Chard
08-09-2002 08:18 AM
