still looking for some ER intercooler
I hate to said it but I think ER SMIC is much better then that, there was so many data has shown in the past to proof it, beside I don't want my car look all hack up with pipe sticking out. FMIC also cause engine over heat a little in the summer, I had seen a few car over heat with FMIC
um the reason you pay the premium for the duh is because the pipes dont stick out, its not some cheap **** fmic from ebay, and what idiot doenst have an elec fan with a fmic? no **** they will overheat
but isn't it duh also require alot more hack to the front bumper? and the IAT is not better then ER?
you do have to cut into the support, but its really not that bad, i got a spare already modded center bumper support with it when i got it, so they could jstu be swapped. but the IAT delta is better then anythign else out there, but yea it should be when its 2200 new, there are a bunch of logs in teh archives, check it out the ic does a phenomenol job
the iat is better on the duh, the delta / per effort of install, the ER beats it by a lil, there is no ic that beats the duh in performance yet, it still is the best, jsut maybe not the easiest to install, liek i said i have the extra bumper support fo you dont have to hack up yours, and can always go back to a different setup as there is no permanent modification
