Stock filter vs ITG-Test #2.....
#11
Interesting - do you still have the S-flo pipe in the airbox (with stock filter)?
I know Mike mentioned that, I wondered if that changes the reading over just a stock filter alone.
Either way I'd probably run it the way that seems to flow best!
By the way I recently tested the S-flo w/new ITG filter on my 2000 Stage I car vs. a new stock filter, and basically they were the same, so no gain in this case anyway.
#15
threadjack, how accurate is the 5115 in your formula with block002? I saw AF 10.5, 1bar @6700
this log was pretty strange, I only got 287g/s? MBC alone set at 1 bar. stock fueling.
#16
One little catch we noticed since then - ECU can request greater than 100% injector duty cycle
so the injector time in block 002, if > than 100% duty cycle, is now only theoretical and not actual. In this case you instead use the time in ms for 100% injector duty cycle in your air/fuel calc:
100% duty cycle time in ms = (1 / (RPM/120000))
i.e. so if the logged injector time is greater than the 100% duty ms value, use the 100% duty ms value in your air/fuel calc. Otherwise it will look extra rich when it really isn't - in your case, if your inj time was greater than 17.9 ms at 6700rpm, use 17.9 ms instead. (then you'll come out with a more reasonable 12:1 I think)
#18
I'm pretty sure Mike still has my ghetto home depot intake in his airbox. ;-) I think
that is making some diff too. Maybe just put the bell mouth in there and use the stock filter?
