Stock horsepower numbers
Old 05-25-2004, 11:37 AM
  #11
Craggy Old Man
Ming 2.7T's Avatar
3250lbs. ? is that light? just wondering
Old 05-25-2004, 11:41 AM
  #12
chimichurri00's Avatar
Default Re: 3250lbs. ? is that light? just wondering
Not sure, that's what AWE put on the printout. Dont think it affects hp though.
Old 05-25-2004, 11:44 AM
  #13
Rob O's Avatar
Default "Conservative"??? 18% drivetrain loss is pretty damn optomisitic, isn't it?
I use a 25%-28% loss factor.
And to get 273 hp from stated 224 hp dyno results would take 22% ... no? ;-)
  #14
AudiWorld Expert
Mark P's Avatar
Mudstain too
Old 05-25-2004, 11:47 AM
  #15
AudiWorld Expert
Mark.core's Avatar
Aren't the stock figures quoted using 91 octane?
Old 05-25-2004, 11:51 AM
  #16
AudiWorld Expert
Mark P's Avatar
Default 224 / 0.82 = 273
Recall we are talking about a "percentage loss" (from the original crank).
Thus if the original crank is 273, and you are losing 18%, you end up with 82% of your original, thus 273*0.82=wheel
thus if you start with wheel, you must:
wheel / 0.82 = crank
NOT:
wheel * 1.18 = crank
(this is not 18% loss)
So, when AWE does:
wheel * 1.28 = crank,
it is really the same thing as:
wheel / 0.78125 = crank
thus suggesting "21.875% loss" for their dyno (not 28% loss as it may appear)
Old 05-25-2004, 11:52 AM
  #17
Default I was using 93 octane.
You mean AoA stock figures?
Old 05-25-2004, 11:55 AM
  #18
Rob O's Avatar
Default Gotcha ...
You are correct sir. I was going about it the other way (AWE example).
  #19
SchagenWagen's Avatar
Default Re: Stock horsepower numbers
Like I said before, I have my reasons to question 17 WHP difference in the afternoon runs.
That 308 WHP stage 1+ XR made me smile too.
Old 05-25-2004, 11:56 AM
  #20
AudiWorld Expert
Mark P's Avatar
Default yes "Conservative", if Dave said there was more loss, this would calculate to a higher crank HP #
thus using 18% loss yields a conservative Crank HP result.
Also recall that this loss # is specific for the hub dyno with S4 attached. It may be a different # for the S4 not on the dyno, or the S4 on a different dyno.
Quick Reply: Stock horsepower numbers
