Strange Electrical Issue
When I turn the ignition to the ready position the EPC and Check-Engine light start flashing on and off rapidly, not like a real warning signal, but like the readiness check gets interrupted, starts again, and so on. The car turns over but will not start.
This happened a few days ago for the first time after the car simply cut off while driving. I called a tow and while waiting I tinkered around a bit and thought I found a loose wire from the zeitronix install I just performed. I disconnected the zeitronix from power and the car started up again.
Drive it around for a few days with no issues. So today I decide to figure out the problem - I put it the garage, look at all the electronic connections - everything seems to be in order. I try to start the car: flashing EPC and check-engine light. So I do what I did last time and disconnect the zeitronix again. No difference.
I have uninstalled everything related to the zeitronix completely and still the same problem. Clearly the zeitronix stuff was not the issue the first time but why would disconnecting it from power temporarily solve the issue?
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Rory
I had to have it towed to the shop in the meantime. The AAA guy managed to tear a hole in the oilpan, so now that has to be done before the diagnosis can start. The shop owner mentioned that the ECU could be the issue as well.
I do have a VAST RS6 tune about 4 months old at this point. Reflashed as far as I know. All the shipping to and fro could have cause the chip to wiggle loose maybe?
So, no way to tell without opening the box then. After 2 days looking at every visible sensor, fuse and electrical connection my money is on the ECU, but before I send it to VAST I would like to be sure.
So, it was just a loose main ground wire....must have been loose for a while, maybe since the turbo swap, and the last few bumps in the road were enough to wiggle it free. Good news, but I still feel stupid for missing it.
I didn't get to talk to the mechanic and the guy behind the counter could only say it was under the hood and off of the main wiring harness, which doesn't help much because everything is off of the main harness.
just curious, did you have any trouble with starting the motor? ive had grounding trouble before on another car
