Strange transmission incident last night-->
When I park the car, I always shut the engine off, depress the clutch and engage 1st gear. This is 100% of the time, whether parked in my completely level garage, or in a parking lot at the store.
Last evening, after coming home from work, I hopped in the car, depressed the clutch and started the engine. I tried to move the shifter from 1st to reverse, but it just wouldn't go into reverse. I thought I wasn't aiming it correctly, but no dice, it just wouldn't go into reverse. I moved the shifter to neutral, released the clutch, then depressed it again and went to reverse again. Reverse engaged normally. Never had any problems like this, and it didn't happen any of the other times I parked the car. Should I be concerned?
Just put it in nuetral and let out the clutch so things line up again. Sometimes you may have to do this twice if you are unlucky.
