stuck bolt
stuck bolt
I am trying to change the cv boot on my b5 s4 (front left). I am following the procedure in the technical articles section. I have taken off the tire, the hub bolt, and removed the nut from the bolt that hold the two linkage joints into the main control arm. But I can't get the bolt out. It's like the head has been spot welded onto the arm. The head of the bolt won't turn. I can't tap the bolt out. It just won't move. So...what should I do? Is there another way to get the outer CV out of the hub? Can you think of a way to get the bolt out, or why it won't budge?
