Suggestions on a good compound for buffing out surface scratches, and swirls? Using an
Old 09-20-2006, 06:58 AM
Senior Member
S4Poor/deux@Curbside's Avatar
Default Suggestions on a good compound for buffing out surface scratches, and swirls? Using an
orbital buffer to accomplish this.
TIA-
Old 09-20-2006, 07:06 AM
Audiworld Sponsor
DAP@EPL's Avatar
Default Orbital? Yikes! Be careful... can quickly burn through the paint with a direct orbital buffer.
Random orbital (such as the Porter Cable buffer) is pretty safe. Ask on the detailing forum... there are some great detailers on there.
-Dave Pramanik
Old 09-20-2006, 07:12 AM
New Member
S4MarkS4's Avatar
Default From my experience and everything I read.....
Random orbital polishers are safe because they don't have hardly any cutting power, therefore you will be there forever if you want to take out swirls. You need a circular polisher to take out swirls but if you don't know what your doing it can burn through the paint. You need to be extra careful on creases/ridges on the car as they will become hot spots if you do not let up pressure there.
Also, I believe the negaro blue color has no clearcoat. I do not know how this affects the process.
Old 09-20-2006, 07:13 AM
EE:OutofBounds's Avatar
Default Meguiars 83 and 82......i would suggest not using an Rotary!!!
you will burn your paint if you are inexperienced!! Use a Dual Action Random Orbital PC and work it slowly with a medium pad. Go to a more agressive pad if needs be.
Old 09-20-2006, 07:14 AM
AVANT S4 KING's Avatar
Default All S4 colors, except Casablanca, have a clear coat
...and its spelled Nogaro.
Old 09-20-2006, 07:15 AM
New Member
SilverS4AVWP's Avatar
Default Meguires swirl remover. works everytime with orbital. Been using it for years....
I've always had black cars until recently, this is the best stuff out there for swirls.
washparkS4's Avatar
Default Like DAP said, use a random orbital not orbital and search the detailing forum. Depends on the how
deep the scratches are before determining which products to use.
Old 09-20-2006, 07:23 AM
Senior Member
Thank you all. Porter Cable buffer it is.
Old 09-20-2006, 07:25 AM
wagongotya's Avatar
Default There is a special from adams on the detailing forum...170 with a bunch of extra goodies
I'm probably going to get it this week
Old 09-20-2006, 07:26 AM
Senior Member
Default I found one here. Seems like a great price IMHO.
<ul><li><a href="http://www.tylertool.com/por746varspe.html">http://www.tylertool.com/por746varspe.html</a</li></ul>
Quick Reply: Suggestions on a good compound for buffing out surface scratches, and swirls? Using an
