Super Sized K04's inside (HSSSK04-5's) (edited)
#51
Hi Von,
We have already made almost 600 with these...
If you guys want a kit it can be done. Just that the economy of scale is likely very poor. So a fewer amount of customers will have to absorb R&D.
It looks likely that good running Stage 3 software will work.
IMO you will likely need a larger than RS4 maf to properly measure airflow.
Jeff
Jeff
#52
Untill two cars can be run at the same dyno under the same conditions there is no way to compare.
This is not meant with ANY disrespect.
Jeff
Jeff
#53
And besides, taking internals from one turbo and housings from another truly isn't a new idea. Now are they using the exact parts that you are? Who knows? However, they are claiming the same numbers from a similar hybrid setup, thats all<ul><li><a href="http://www.dahlbackracing.se/english/main.asp">Dahlback Racing</a></li></ul>
Too lazy to STFA - Wheel Worx vs. Ye Olde Wheel: which one should I go to? Wheel Collision Center in
TwinTurboTerror
Mid Atlantic Discussion
10
11-12-2006 06:07 PM
for the snail heads.....i've heard mixed things about clipping the wheels....is anyone familiar with
Arcteryx::Stock Rods
27
09-15-2005 08:31 PM
