suspension install gurus: what's your trick to tighten those peticular nuts "at ride height" when
that's impossible to do when the wheel is on and the car is on the ground? Do you all use a jack and raise the lower control arm (assembly) up to where you think it will rest when on the ground, and then tighten (with the wheel off of course)?
Thanks.
Thanks.
so the bushings are in their rest position. I usually have a car on a lift and just lower the lift down while I support the lower control arm with a transmission jack. When that corner of the car unweights from the lift arm just a lick I tighten.
Cheers,
Cheers,
sergeyk
03-12-2009 03:46 PM
banana s4
09-22-2006 12:45 PM
GrizzQuattro
03-09-2006 11:08 AM
