sway bar end link failed on me!
so i was driving my car and having a good time untill a hear a clunking noise from the right rear. To make a long story short my right side sway bar end link not only went bad but it snaped in half...i found this very odd just wanted to let you guys know
Former Vendor
Pick up the all metal links.
<a href="http://www.purems.com/products/product.php/II=968">Left Rear</a>
<a href="http://www.purems.com/products/product.php/II=969">Right Rear</a>
Where did it fail?
Did it fail at the joint or elsewhere?
Plastic or metal?
Stock anti-roll bar or aftermarket?
I haven't heard of many of these failing. I'd bet the failure was at the joint and that it had probably leaked or failed for some other reason.
As Mike said, the solution is to replace them. You can only buy the metal ones now. If you are using a larger anti-roll bar then they are probably wise anyway.
Oh, if the other link is still in good shape when you take it off then send it to me. I use them on my winter set-up because they're lighter but can't get them anymore. :-)
Stephen
Plastic or metal?
Stephen
oc_tt
07-12-2008 07:03 AM
Ray Khan
08-17-2004 09:27 PM
Phil
03-20-2004 03:13 AM
