System too rich DTCs. suggestions?
codes below. I was thinking I could pull some fuel back with lemmi. thoughts?
DTCs: 7/31/05 12:59 pm - 4 Faults:
MS STAGE 6.0 0003
P/N: 8D0 907 551 HA
Coding: 06711, WSC: 05052
16815 P0431 035
Warm up Catalyst Bank 2: Efficiency Below Theshold
16805 P0421 163
Warm up Catalyst Bank 1: Efficiency Below Theshold [Sporadic]
17537 P1129 163
Bank 2 Mixture Adaptation (Mult): system too rich [Sporadic]
17535 P1127 163
Bank 1 Mixture Adaptation (Mult): system too rich [Sporadic]
MS STAGE 6.0 0003
P/N: 8D0 907 551 HA
16815 P0431 035
16805 P0421 163
17537 P1129 163
17535 P1127 163
I suppose either or both could be gone. I'll do some logging on Block 211 to see what comes up for the MAF. Thanks DAP.
Also, there's a few reasons you could run rich.. (besides the BOV :-p )
In addition to bad MAF or o2 sensors (logs should show that), you may also have a boost leak. Before adjusting fueling, try and find out what else could be the issue. (if you pull fuel back now, then later fix a boost leak, you'll run super lean, not good)
then post the info and list your mods. Based on that, we should be able to help you identify an 02/MAF issue.
