TBB Starting to go.
I'm at about 17,000 miles on an '00 S4. I haven't been experiencing any real loss of boost, but decided to pull the infamous TBB to take a look. Sure enough, just as Don P. discovered, I had some deep cracks right under where the underside of the clamp's screws dig in to the TBB's rubber flanges. Thankfully, the cracks had not worked all the way through to the interior sides. I ordered the new TBB and clamps at the local dealer. In the meantime, I've patched the existing TBB using a bike tube repair kit. Also, coated the 'points' on inside of the clamps with liquid rubber..hopefully they won't cut into the TBB any further.
Anyone had problems with the rubber tubing further downstream toward the turbos?
Please just replace the TBB, you risk too much with the patches, the TBB expands and also gets much hotter than a bike tire patch was designed to handle. The patch piece may come loose and get sucked into the engine!
Don't mess with the air system on this car, mistakes are too costly.
I feel ok driving the car. Of course, if it ruptures between now and when the new TBB comes in, it'll be parked until the repair can be done.
svenson69
10-23-2008 01:39 PM
NoFHoes
05-22-2002 11:53 AM
