test drive & first impressions...any comments
Guest
Posts: n/a
must apologize if this has been mentioned in previous posts,but i haven't had time to sift through all the messages.
i was fortunate to have taken a 6spd S4 for a test drive this past weekend. i found the power readily available and quite impressive. however, has anyone experienced any difficulty in putting the car in the right gear? was it my imagination or were some of the gears pretty far apart? also, has anyone found the suspension slightly on the soft side? your comments are appreciated...i'm still deciding on whether to take the plunge.
Guest
Posts: n/a
Some have mentioned the gear throws are long. I have not personally had any trouble shifting, unless you count reverse, my older Audi had reverse where this one has 6th, but otherwise, I'm happy with the shifter.
But then, I did learn with a steering column manual shifter, and anything's better than that!
The suspension is stiff, for it's class, but does have a soft range for minor bumps, stiffening up for deeper excursions.
Guest
Posts: n/a
The action on the S4's gearbox i find is very un "sports car" like, having a large gate and gears that just wont be rushed, It does have to deal with a huge amount of power and the large weight of the car but the japanese seam to have no problem making quick shift boxes.
However with the ample power available you soon learn to pretty much ignore the box and drive around it.
For me a TT Style box would be a dream. (or even quicker)
The RS4 has a very similar action
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Dave
Guest
Posts: n/a
I also missed the correct gear once on my first test drive, but I was very used to the gear box after one full day with my car. I have not missed a gear since. The suspension is a matter of personal taste. If it is to soft for your liking just get Eibach springs and Koni shocks. I have had my Santorin S4 for almost 2 months and 3500 miles with no problems.
