Theory regarding boost taper problem:
Old 09-02-2004, 06:21 PM
  #41
Audiworld Sponsor
DAP@EPL's Avatar
Default I think I'm with ya on that one, Doc.
Eventually, I'll have some K04 or custom software with no taper (perhaps sooner than later).
-Dave Pramanik
Old 09-02-2004, 06:29 PM
  #42
Mike2kS4's Avatar
Default I'm "all about" exorcising the taper from my setup ;)
Thats why people like you need people like me. I don't hesitate to screw around with stuff, plus I share what I find out, good or bad
Old 09-02-2004, 06:32 PM
  #43
Mike2kS4's Avatar
Default Yea, I'm going to count the turns and such, and test them with an air compressor.
So I'm not going all crazy-haphazard here.
Old 09-03-2004, 01:29 AM
  #44
808Guy's Avatar
Default My DSM friends swear by the original Profec B
seems it's easier to use and preforms better than newer models.
Old 09-03-2004, 01:33 AM
  #45
808Guy's Avatar
Default AMS to a local stage 5 owner to do the same thing
He had a shop tighten his wastegates atleast on 2 instances. It got to the point that the shop was uncomfortable making the adjustments even if Mark at AMS insisted it was ok. I believe they tighted the wastegates about 10 threads on each side.
Old 09-03-2004, 07:15 AM
  #46
Angular's Avatar
Default That's cool, 'cause you piggie guys tend to just go HOG WILD with MBCs, TCDs, TIPs, XYZs, PDQs. :P
hehehe...
Old 09-03-2004, 07:45 AM
  #47
VonK :: Retired's Avatar
Default Thinking out loud .... --->
If the MBC maintains <b>constant</b> pressure on the WG actuator to set max boost, then the WG will be pushed open further as the TIP rises with increasing engine speed at WOT. If the actuator rods are shortened, the MBC must be reset to hold the same max boost, and the WG will again open further with increasing TIP. I don't believe this will solve the problem.
The above premise about <b>constant</b> MBC pressure is debatable, since ball valves typically require a higher "cracking" pressure to open compared to the flow pressure to just keep them open. And there will be some flow either through the MBC bleed hole or the N75, depending on the installation. I have the installation shown in the picture but haven't yet analyzed the observed pressure patterns. They're surely complex.
<img src="http://209.128.70.155/ManBoostCtrl2.jpg">
Old 09-03-2004, 07:58 PM
  #48
Mike2kS4's Avatar
Default Nice illustration! I already purchased an EBC...
Hopefully that, combined with the WG rod tweak, will greatly reduce this. If not Jacob has some higher rate actuators he's working on.
Old 09-03-2004, 08:00 PM
  #49
Mike2kS4's Avatar
Default Wow. Jacob is going to give me some #'s on the turns/lb...
Pending that, I'm doing 3 turns between measurements.
Old 09-03-2004, 08:26 PM
  #50
Angular's Avatar
Default I would exhaust all/most other tests before resorting to that. If N75 or other means can...
... maintain flat boost to redline, then the WG spring rate is not likely the issue.
Besides, I can't imagine it's easy to get in there and physically access those WG actuator arms, is it?!
Quick Reply: Theory regarding boost taper problem:
