On these logo's for brake calipers.....
I got the rings, how the hell do you get them off the tape and the caliper, when i pull the tape the logos come off with them. I don't want to screw them up. Please be gentle if I am being a dumb F^^k!
do not remove the rings from the tape, but apply to tape to the caliper,,,face down of coarse and then try pulling the tape off. hopefully the rings will stick to the caliper and not the tape.
other side if the tape. Thats normal if it is a decal. Apply the rings to the caliper when still attached to the tape. But pressure on the rings so they stick to the caliper. Finally pull off the tape. The decal should stay on the caliper as you pull off the tape.
I hope this helped. If not, sorry.
I was used to decals peeling off from clear tape. Just press the entire thing on the caliper, use your nails to get the rings down, and then peel back.
