Thinking of trading my S for an S2000, any takers?
#21
Bolts on the heat shield and downpipes were toqued down by an airgun when the engine was out....You know how hard it is to get out by hand? Those bolts ain't easy to get to man.
#22
it to reach the post-cat O2 holes. There is slack in there, i promise. Whatever you don't need you can zip-tie. We had to reroute the sensor wires at the junction boxes at the back of the engine bay to find enough slack for the AWE pipes' holes. PITA, too...
#25
Hell, Pat's car didn't have anything wrong and we had to duct tape his O2 sensor back together....Rewire the sensor wires back togethere, there are 4 of the, so make sure and get it right.....Also, get someone with an APR computer to disable your 2nd O2 sensor....I think that's part APR's program though? So try switching your O2 sensors around.....FYI our install took just over 12 hours on the car.
#26
I actually like the cars. They handle like a Miata and pull like one with a turbo. But you had better be in the right gear coming out of the last turn in to the straits. I spool up purty quick
#28
Not our fault....took us 3 ours on 1 friggin bolt....That bolt that sits on the top of the heat shield and downpipe.....can't reach that with ANYTHING....and it was cranked down damn tight....
#29
You should have zip-tied the 02 Sensors to the frame, but not in baggies or anything...Just open-ended. If you joined two wires together that weren't supposed to be, then the current may have been misdirected, hence the "Unknown code" DTC. I'm just hypothesizing myself. I'm no electrical engineer. But Rob Chang is...Ask him on the S4 Atlanta forum. He may be able to help: (Atlanta-S4@yahoogroups.com)
