Those with 90mm+ MAF, what did you use to connect it to the y-pipe?
Old 03-24-2005, 12:22 PM
jstabb's Avatar
Default Those with 90mm+ MAF, what did you use to connect it to the y-pipe?
I don't believe the RS4 accordion hose will fit larger MAF housings (I have a 90mm lightning MAF). So I'm curious what people have done to connect the MAF to the y-pipe.
I STFA and found someone that had used what looked like a heavy duty dryer hose, but wanted to see if there were any other options. I looked at silicone reducer hoses, but they appear to have a pretty abrupt reduction in diameter, not to mention after adding a reducer you end up with a pretty sharp bend to make the final connection.
Any input would be greatly appreciated.
-James
Old 03-24-2005, 12:31 PM
Todeshandler's Avatar
duct tape.
Old 03-24-2005, 12:34 PM
Member
AudiS4guy - NorCal's Avatar
now thats ghetto =P
ryans4's Avatar
when used on a car, it's called "racing tape"...
Old 03-24-2005, 12:36 PM
Superglue works also.
Old 03-24-2005, 12:47 PM
jstabb's Avatar
I already replaced tbb with that, wasn't aware I could do the accordion hose as well
Old 03-24-2005, 12:54 PM
lemieux@curbside's Avatar
Default this is all you need here (get same or a bit smaller size )
it will stretch a bit anyway<ul><li><a href="http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=CTGY&amp;Store_Code=tp&amp;Cat egory_Code=SIL">hoses</a></li></ul>
Old 03-24-2005, 01:30 PM
jstabb's Avatar
Default Those seem short. Also MAF OD = 4"; S4 y-pipe OD = ~3.44"
Thanks for the link,
Can you give more details? Because unless I'm missing something (all too likely), I don't see how those will work. 1/2 inch reduction in the space of an inch doesn't look good for airflow. Unless you mean a straight hose will stretch by half an inch, in which case the RS4 accordion would have a little less stretching to do.
Old 03-24-2005, 02:05 PM
gandolf the white's Avatar
try a hose from a ford seems they should make them
AudiWorld Expert
nyet's Avatar
ah yes, the diego method
Quick Reply: Those with 90mm+ MAF, what did you use to connect it to the y-pipe?
