For those that change their own oil while on rhino ramps, how full do you fill?
AudiWorld Expert
does being on the incline of the ramps show less oil than when back on level ground? It seemed as such for me tonight.
I dump in 7 bottles, disconnect the ignition amps on the airbox, crank the motor in ~10 second bursts or so for about 30+ seconds. Pre priming is a good thing ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Reconnect amps, start car, check for leaks, back off ramps, let it idle, turn engine off, wait a few minutes, top off as needed.
just fill the new filter 1/2 to 3/4 of the way up before installing.
and i know it's hard but i tried to get as much oil into the new filter as possible before starting the engine.
I collapsed the lifters once quite a while ago doing a change with something less than a 1/2 quart in the filter. Sound made me sick to my stomach, was about to cut the ignition when they pumped back up.
It was the only change it had happened on, maybe I let it drain too long, but after that I started doing the preprime with the starter.
Takes less time for me than filling the filter by hand and I like the dead silent normal start after a change.
YMMV, TEHO, etc
YMMV, TEHO, etc
IIRC, that change was done on a hot motor and I got side tracked and let it drain for over an hour. It was last year sometime.
Pulling the four connectors on the airbox is quick and easy and makes me feel better. No oil consumption at 103k so it doesn't hurt. Though you've got me beat in the mileage game
