Those of you with AWE downpipes: Do you need the "olive" when clamping the flared pipes? Or will the
olive clamps alone work? I have both pieces but I can't seem to figure out how the olive fits between the two pipes or in the olive clamp...the olive clamp itself is a no brainer though. But when I put the olive in, it seems to jiggle around when it's clamped.
This is the olive clamp, should be familiar:
<img src="http://www.motorcarsltd.com/itemimages/IN101534.jpg">
And here's the olive i'm referring to:
<img src="http://www.motorcarsltd.com/itemimages/IN101760.jpg">
Do you remember what to do with this? I bought these clamps from a Jaguar site since AWE uses these same exact ones.
AudiWorld Expert
<img src="http://www.awe-tuning.com/media/products/awe/27downpipes/27dp_ballsocket.jpg">
<img src="http://www.awe-tuning.com/media/products/awe/27downpipes/27dp_fullset.jpg">
<img src="http://www.awe-tuning.com/media/products/awe/27downpipes/27dp_uppers.jpg"><ul><li><a href="http://www.awe-tuning.com/pages/info/content_window.cfm?content=21">http://www.awe-tuning.com/pages/info/content_window.cfm?content=21</a</li></ul>
and if so, does it just slip in between the clamp? It seems really loose when it's in there; that's my concern.
I actually looked in the pipe as I shake it and you can see it hopping around between the olive clamp. What do you mean by lining it up? Clamps aren't exactly rocket science here but this olive insert doesn't want to stay in place.
the outer ring. The piece should almost be covered by the pipes. Hold them tightly together and then gently tighten the clamp. The clamp will hold and tighten the joint but won't pull it together on it's own if you know what I mean.
