those of you who have had a leaking afterrun coolant pump...
Did you notice anything in particular that was causing the leak? Is there a certain fitting or seal that may be the weak point? Any way of telling if it was leaking all the time or only while it was actually running?
thanks in advance
thanks in advance
i am on my 3rd one and now this one is bad enough that it leaks all the time and coolant runs out of the valley and is soaking my clutch...
i hope to come up with some sort of a new solution
I'm pretty sure mine only leaked when it was running. Once I knew it was leaking I would peer under the intake mani periodically, but wouldn't always see fresh "wetness" (LOL) after driving. I suppose a better check would have been to hammer on the car for a while to trigger it, then have a look. It was pretty messy regardless so I just decided to replace it.
raj//UrS4
Audi Original "S" Cars
02-26-2007 05:27 PM
s4gonebabygone
10
02-07-2005 04:10 PM
LosGatosS4
16
10-10-2003 12:56 PM
Kirath ¾-B0§t0n
10-30-2002 12:06 PM
