Throttle Body Adaptation Problem and Question - HELP!
Just did a TBA with the VAG tool and experienced something that seemed strange to me.
The adaptation process started after switching to basic settings and displayed ADP-OK (or whatever the little right text field displays) but the % values continued to switch between 84 and 85% it never locked on to one value, and I just exited the module.
I turned key-off, removed vag cable, turned key on, waited about 30 secs and then started the car. The engline made a weird noise, like it wasn't too happy, and started right up with an idle around 1300 RPMS.
I turned the car off, repeated the above process, everything happened the same way again and the idle was high again with the weird noise at start-up. This time I left it running and the idle dropped slowy to normal over the next few minutes.
I decided to come post before I drove it just to make sure nothing is out of sorts.
Also, the first time I did a TBA, I had no problems it started and idled just fine right off the bat. Anyone have any ideas why this time everything seems so screwy?
TIA =)
TIA =)
Then popped the other ECU right back in an re-adapted. That's when this funny business started.
should I use the old key in ignition when cold routine.
SO the loud sound/jumpy rough start at startup from the car being in "choke mode" and nothing to worry about?
I'm excessively paranoid about these things. =)
Thanks for the help Taner.
Can throttle body adaptation be done without a Vag tool? I have read here that turning the key to on
S4@last!::Now B7 RS4
11-17-2001 11:20 PM
