Throttle position sensor help
Car won't start, unable to pull codes when the Throttle position sensor (on top of TB) is connected, and motor on the Throttle body clicks loudly when the key is in accesory position.
Had very poor idle symptoms, and surging/cutting out for a day before car wouldnt start. ABS, ECM and CEL lights as well.
Codes 17952 & 17580 - same symptoms as linked post except my car is 6 speed.
Did not get " Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal" however
What parts do I need to look at? Its not the Throttle Body is it? Possibly accel pedal w/ electronic module? Part # 078133062C? TIA<ul><li><a href="https://forums.audiworld.com/s4/msgs/2766905.phtml">https://forums.audiworld.com/s4/msgs/2766905.phtml</a</li></ul>
German Driver
NY / NJ / CT Discussion
02-22-2007 08:15 PM
djdc
Audi 100 / A6 (C4 Platform)
12-24-2004 12:16 AM
