Throttle re-adaption procedures?
The search engine is down, so I couldn't find the info. I know there is somebody out there that can help. What is the VW tool procedure for re-adapting the throttle? The MTM chip has been in for about a month and VW tool says the throttle doesn't need adapting. Do you have to clear the "default" adaption from when the chip was installed and re-adapt? There are still smoothness issues with the current adaption.
Throttle Adaptation
For VWTOOL, (ignition ON, engine OFF!) select ENGINE, then BASIC SETTINGS, then entry 060 in the data block select window and press "accept". You can then hear the engine throttle cycle, and see the graphic display of the adaption cycle. The last value will change to "Adapt OK" when done.
mike
mike
and_s4
05-14-2002 10:17 PM
ed@4induktion.com
10-09-2001 05:01 PM
RuS4
10-12-2000 05:19 PM
meem
09-02-2000 12:24 PM
