Time to play everyone's favorite game, Name the broken part!
I found it while cleaning my door jams, It was poking out of the drip opening at the lower corner of the driver's door. I had to extract it with pliers, I didn't do any more damage to it. It's broken to a small extent, like some little tabs came off.
Sorry for the poor quality pics
<img src="http://pictureposter.audiworld.com/54947/thing1.jpg">
<img src="http://pictureposter.audiworld.com/54947/thing2.jpg">
<img src="http://pictureposter.audiworld.com/54947/thing3.jpg">
My only guess its some kind of slide for the window glass, keeping it from rattiling when down or something. I've had no noises or any problems with the door. I know it's been like that for awhile as last time I saw it, it shot back into the door when I tried to grab it. Some hard launches brought it back to where I could get it
AudiWorld Expert
Not sure exactly what it is though...
I think those are the power window connectors that are hanging in front of it.
Front door:
<img src="http://ctny.audiworld.com/mark/a4/system/stock/mvc914f.jpg">
Rear Door:
<img src="http://ctny.audiworld.com/mark/a4/system/stock/mvc003f.jpg">
<img src="http://ctny.audiworld.com/mark/a4/system/stock/mvc004f.jpg">
Front door:
Rear Door:
<center><img src="http://pictureposter.audiworld.com/4863/stripped.jpg"></center><p>It has to be with the motor.
You will see a black bolt that needs to be removed. Do not use power tools and use liquid wrench to saturate it since there is a ton of lock-tite. Unplug the seat from the bottom. Pull the seat forward. Go to the back and take the screws off the back under the plastic covers. Get a huge flat head and use it as a guide on the inside rail so it doesn't turn on you. Get help from a friend and push back and up. Lift the seat out through the back door.
