Time to point and laugh..
VAG-COM Version: Release 512.1-UD
Thursday,09,March,2006,17:29:24
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine
Part No: 8D0 907 551 M
Component: 2.7l V6/5VT G01 0001
Coding: 06711
Shop #: WSC 09110
8 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16690 - Cylinder 6: Misfire Detected
P0306 - 35-00 - -
16689 - Cylinder 5: Misfire Detected
P0305 - 35-00 - -
^^^^^^^^^^^^^^^^^^ Using the whole roll is OBVIOUSLY to much hp for this pathetic little engine to handle :/ ...
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17538 - Fuel Trim; Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
Address 08: Auto HVAC
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 63251
No fault code found.
Skipping Address 15-Airbags
Address 17: Instruments
Part No: 8D0 920 981 B
Component: B5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 63251
Address 35: Centr. Locks
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 63251
4 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63251
1 Fault Found:
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
35-00 - -
Address 55: Xenon Range
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63251
Address 56: Radio
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 63251
End~Enjoy
TonyB
90 CQ
00 A6 2.7t manny
Annapolis, MD
Address 01: Engine
Coding: 06711
Shop #: WSC 09110
8 Faults Found:
P0103 - 35-00 - -
P0300 - 35-00 - -
P0304 - 35-00 - -
P0306 - 35-00 - -
P0305 - 35-00 - -
P1128 - 35-00 - -
P1130 - 35-00 - -
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
P1857 - 35-00 - -
Coding: 00160
Shop #: WSC 63251
Coding: 02264
Shop #: WSC 63251
Coding: 16140
Shop #: WSC 63251
4 Faults Found:
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00101
Shop #: WSC 63251
1 Fault Found:
35-00 - -
Coding: 00012
Shop #: WSC 63251
Address 56: Radio
Coding: 00110
Shop #: WSC 63251
End~Enjoy
TonyB
90 CQ
00 A6 2.7t manny
Annapolis, MD
and yes it means i can do the whole flip spin roll and knock things off the bottom of my car..
Cause if that's all that happened, your VERY lucky it didn't go all the way through the engine...
