Timing belt diy question...
Im somewhat stuck and need some advice.
From several writeups,most have said they avoided partially removing the cam sprockets but the bentley and other writeups have said otherwise.
I just took off the timing belt and have the cam lock bar on. What is the general consensus on the steps from here?
just made sure to mark the hell out fo the sprocket teeth and make absolutely sure i wasn't off when i put the new belt on.
way to ensure that you have the correct timing. Otherwise you're taking your chances. You might get lucky or you might end up with a noisy engine.
You need to get the cams back to alignment with the cam lock bar and keep them there by pulling the cam sprockets off, replacing the belt, pulling the pin on the tensioner, THEN torquing down the cam sprockets. You want the cam sprockets to "twitch" slightly when you pull the pin. Now, the belt is on, the pin is pulled and the timing is perfect. Torque down the sprockets.
cam timing which effects your power. Would you install new turbos and not set the wastegates properly? Would you install new suspension and not get an alignment? Popping the sprockets doesn't take long if you borrow a gear puller.
hubturn
16
02-20-2022 07:20 AM
Tofu4679
02-12-2008 05:38 AM
Xymox007
01-08-2003 08:35 AM
