Timing chain tensioners.....
160k miles. Over 80% highway. Car is in for stg 3 and new springs. After labor, I will, as expected be way over budget. Then the mention of of chain tensioner seals comes up. The mech wants to pull the tensioners etc and replace them, as they have to be removed to get the seals replaced anyway. My issue? New chain tensioners cost about the same (within a few hundred) of a low milage used 2.8 setup, I am hearing. While that could be wrong, I'm not in a position to replace the cam tensioners and pay what sounds like 4+ hrs labor.
I can review options involving 2K or so expenses again in about 10 months. Am I going to get 10K or so out of these, in the mean time, if needed?
Also, is there a way to replace the tensioner seals without pulling everything apart. They are leaking a small amount, it seems.
It's a belt, and if you value your motor and the money you put into it, you do it right the 1st time
With a higher mileage car like that, the biggest cost is the labor. So you should be doing the belt, tensioners and seals, water pump, thermostat, cam seals if they are leaking, valve cover gasket, and anything else you can think of. If you are doing stg 3, then might as well do the rear main crank seal while the motor is out.
They're actually the one part that doesn't fail all the time, you may want to just keep them. You
can replace the seals and keep your tensioners. You have to pull everything apart unfortunately they're a pain in the ***. Wrinkledpants is thinking of the timing belt...
Yep- the belt's been done
And the seals will probably be done if they start a bad leak, or if I have a full weekend to learn DIY, with a tow to shop option for backup ;-)
here is a good write-up from the tech section
and this is the tool you need
<img src="http://images.andale.com/f2/109/101/17613004/1137075188308_vw3366bbb.jpg">
there is no need to remove the chain tensioner to replace the gasket/seal.
there is a few more write-ups to follow here:
<a href="http://www.audidatabase.com/diy">http://www.audidatabase.com/diy</a><ul><li><a href="https://forums.audiworld.com/a6/msgs/600761.phtml">https://forums.audiworld.com/a6/msgs/600761.phtml</a></li></ul>
Shouldn't have to replace tensioners unless they're making noise..
And you don't have to completely remove them to replace the seal. Use the tool that jakecro linked. It's kind of a pain but easier than removing the tensioner, which requires removing at least one of the cams.
Find out more about why your mechanic wants to replace the tensioners.
It fits in the center arm rest. It's the factory coin holder from an Audi 100, and it happens to be
the perfect size to slide in very snugle right in to the front of the arm rest. I got it from Clair Parts years ago which is now Audi Parts Superstore (part of Prime now since Prime bought Clair). They might still have them/be able to get them. I would think Carson could order it also.<ul><li><a href="https://www.audiworld.com/tech/int7.shtml">https://www.audiworld.com/tech/int7.shtml</a</li></ul>
DasTT
08-14-2008 03:40 PM
OneEighty
07-06-2004 08:49 PM
