Tire wear question - anyone ever bothered having their tires remounted to even out the wear?
For stock suspension S4's that do track time, the outside edge of the tires wears a lot more than the inside - esp for the tires on the front.
Has anyone ever had their tires remounted to flip which side is getting the harder wear? That will also result in needing to switch which side of the car a tire is on to match the rotational direction, but this theoretically could give a little more use out of a given set of tires. I am aware that they will need to be rebalanced in the process.
I had a flat last fall with my regular wheels and my spare turns out to have the wrong rotational direction for where it needs to go if I want to use it full time (and on a track), so I need to have the tire remounted anyway. I was getting ready to swap out my snows for a track day and the thought came to mind as I stared at the wear patterns of the tires I am going to mount tomorrow.
Feedback appreciated - is this just a crazy thought?
you described. Don't think I'll do what you mentioned. Although I have thought about it.
i'm gettng quite a bit more wear on the outer edges of my tires that I would have thought. I haven't tracked the car either I guess I just take the hills of San Francisco a bit too aggressively.
20K miles and Pilot sports
inner edge on one of my tires was cording due to all the track edge wear. When I moved that edge inside, it was harder to inspect and I missed it for quite a while.
Sure hope my 245/40-17s fit. Fed ex is bringging them right now.
RR
RR
SmokinS4™
26
05-25-2006 05:50 PM
vpr1980
13
04-22-2005 10:07 AM
Phil type 951
Motorsport Discussion
18
04-23-2003 11:05 AM
Silvr1.8T
Wheels & Tires Discussion
10-02-2002 05:03 PM
