Toluene vs no2 Octane Booster - which one to use...pros and cons anyone?
and if I am not mistaken, those OTC Octane Booster only yield 0.1~0.2 octane eventhough they said 1~2 points. On the other hand, Toluene is a kind of thinnner and i was told they are straight 114oct, so if you were to mix it with say 91oct, 1:15~15.5 then you will end up having 92ish
motor octane. i didnt verify my numbers but i dont think they are far off.
So if you add 3 gals. of toluene to a tank of 93 oct. you'll have about 96 oct. and an increase of about 30 hp.
Octane boosters only add less than 0.1 octane per bottle. You're better off buying a botlle a good
fuel injector cleaner than them.
Also if you're going to add toluene use a funnel with a screen in the spout. There's a lot of junk floating around in the cans.
Then again, if you're in CA and just trying to get from 91 to 93 it would be different. I think it would still be cheaper to mix enough 100 octane with 91 to get to ~93.
8 gal of gas out of one bottle.
15gal 91 + 1 bottle = 94.5 roughly
15gal 91 + 1 gal T Sauce (114 oct) = 92.4 roughly
The "NOS" brand wins, BUT it is the ONLY brand on the market that uses MMT and will effectively raise your octane....
all the other boosters work on a points value where one point= .1 octane raise.... trys to fool you.
