Took off my bellypan and found oil coating everything. What's happening?
Smelled burning oil earlier this week. Oil level is still ok but obviously it's leaking quite a bit.
<img src="http://pictureposter.audiworld.com/4838/img_2500.jpg">
<img src="http://pictureposter.audiworld.com/4838/img_2501.jpg">
<img src="http://pictureposter.audiworld.com/4838/img_2502.jpg">
<img src="http://pictureposter.audiworld.com/4838/img_2503.jpg">
It was fun to see this as well:
<img src="http://pictureposter.audiworld.com/4838/img_2507.jpg">
<img src="http://pictureposter.audiworld.com/4838/img_2505.jpg">
Is this OK?
<img src="http://pictureposter.audiworld.com/4838/img_2504.jpg">
Is this OK?
It's a very very very slow leak like you (oil in same place). Looks like there's a black plastic pump or something on the driver's side that you can only see from underneath. I believe this is where my oil is slowly leaking from (and onto about half of the oil pan). I haven't noticed my oil level dropping however. Your COOLANT leak is BAD! Probably afterrun coolant pump under intake manifold. Fix that CV boot ASAP so you don't have to replace the joint. Possibly look into a rebuilt axle...<ul><li><a href="http://www.raxles.com/">Rebuilt Axles</a></li></ul>
replace it, you can use the part numbers from the tech article and get them from 1stVWparts for under 100 bucks
