Torctite exhaust clamps - I just bought two
Old 02-22-2005, 05:31 AM
  #11
AudiWorld Expert
Mark P's Avatar
Default Hmm, I was about to get those T clamps- so these are basically the APR clamps with 2 bolts?
here's the APR clamp:
<img src="http://ctny.audiworld.com/mark/s4/exhaust/dsc04814.jpg">
The ones you're getting:
<img src="http://www.torcausa.com/images/products/tortitfin.jpg">
T Clamp from summitracing:
<img src="http://static.summitracing.com/global/images/prod/large/sup-094-2000_w.jpg">
Old 02-22-2005, 06:01 AM
  #12
Guest
Another Drew's Avatar
Default They're a little different.
The band clamps (dynomax, jcwitney, etc) are much wider so it covers the whole joint including the overlap. And the band material is thinner so it deforms and stretches somewhat to the shape of the exhaust pipes.
Old 02-22-2005, 10:03 AM
  #13
ClemS4's Avatar
Default Just put my APR on recently and used a similar band clamp from NAPA like FrozenS4. Worked well...
The APR clamp was ok but the nuts and bolts broke under pressure )=.
Old 02-22-2005, 02:03 PM
  #14
davenew's Avatar
Default Yea, you can see the rolled metal of the summit T-clamp
My exhaust has been pivoting at the pipe joint, instead of the flex connections, as it should. THat causes it to rattle against the heat shield during decel.
The T clamps have the hollow rolled metal that bent, allowing the clamp to loosen. It appears to be cheap galvanized steel. I'm afraid I can't apply more torque on the nut without causing it to bend even more.
One of the APR nuts galled when I removed them and the bolt broke. The center piece broke in half on the other clamp. Hopefully, the "reaction block" will give the clamp ear more leverage to tighten the clamp. I also figured the longer clamp would help to stiffen the pipe joint.
Sorry for the false lead on the T-clamps. I just recently realized the problem.
Old 09-03-2005, 08:53 AM
  #15
Junior Member
lookaught::02_Avant!'s Avatar
Default i think you got ripped off at that price
i mean you can get those clamps online for dirt cheap at a lot of stores.
check the link for an example. they sell 3" as well. use high temp gasket sealer on the joints as well just to be sure that it doesnt leak. I used these on my car for almost 4 years with no problems ever.
run the search in this link and scroll down for all your exhaust clamp needs<ul><li><a href="http://store.summitracing.com/partdetail.asp?autofilter=1&amp;Ntt=exhaust+band+c lamp&amp;N=4294919985">clamps</a></li></ul>
beejohn
09-25-2007 05:21 AM
Mike Desi
Audi Original "S" Cars
10-04-2005 06:23 AM
davenew
20
02-26-2005 09:33 AM
EDness
07-23-2003 12:23 PM
Quick Reply: Torctite exhaust clamps - I just bought two
