Torx T-35
I have looked in Ace Hardware. Sears, HomeDepot, Snap-On, Mac Tools and a bunch of others after a google search. I have found 30 and 40, not 35. I will check the somewhat local Sears and AutoZone.
I just finished installing the bipipe. The T35 in the install guide is incorrect.
Most AWers say it's a T30, but I used a T27 to remove my headlights w/o any problems.
Seating the bipipe on the TB is bit tough, make sure that you work the driver-side pipe as you push the bipipe onto the throttle body. Having a rubber mallet handy isn't a bad thing, either ... good luck.
I have a T30 and it is too small for headlights. I found a 1/4" hex on line and may go for it and the extension handle. Thanks for the other advice!
I have a T-30 and it is too small. You can say that again about them being rare. Checked Ace, PepBoys, AutoZone, Checker and Napa.
