Transmission detents....explanation
<center><img src="http://pictureposter.audiworld.com/1510/mvc-365s.2.jpg"></center><p>The S4 transmission uses four "detents" to provide the means to hold the sliding sleeve against the "dog teeth" in each gear. It uses two more to provide the means to hold the shift shafts in their respective positions. What this really means is that they are "springs" with a ball roller that press against valleys in steel plates. When you shift gears...you feel the "gates" as you go into a gear. That is really the releasing or positioning of the detents in its "valley" on a shift fork.
The Porsche 968 uses basically the same internals as does the S4. It too uses 6 detents. The picture (note shameles plug for STOPTECH Brakes) shows the S4 on the left and the 968 on the right. The S4 has an aluminum housing and weighs 56 grams and has about 34 lbs. of spring pressure at about 7mm of preload. The 968 has a steel housing and weighs 91 grams and has the same 34 lbs. of spring pressure at 7mm preload.
When I modify the S4 detents, they then have about 38 lbs. of pressure....a 10% increase. This gives your shift lever a more positive feel when you shift gears.
LI-S4
07-19-2004 05:42 AM
S4 Ding-Batt
10
10-30-2003 10:03 AM
mm
06-15-2001 05:40 AM
silver surfer
04-14-2000 06:08 PM
