Transmission Questions
<center><img src="http://pictureposter.audiworld.com/38842/mvc00146.jpg"></center><p>Does anyone knows, can I change my tip into a manual transmission?How many parts I'll need to get ?How much for those and where to buy ?
The key to this puzzle is ...
<center><img src="http://pictureposter.audiworld.com/3/torsen.jpg"></center><p>This and Jim De Arras to put it all back together again. Behold the mighty torsen!
here's a small list:
-transmission
-pedal box assembly (may be differnet on tip or 6sp)
-clutch
-clutch pedal and associated cabling
-new master cylinder to feed clutch (since it's hydrolic)
-all associated tubing for above
-new front axles
-new rear differential
-shifter and linkage
-new transmisson ECU
-new motor/tranny mounts
-lots and lots of labor
-clutch
-new front axles
yes but...
it would be so labor intensive and cost prohibitive that you would be better of buying a different car. since the TIP is the superior trans I cant imagine why you would want to change it however....
